Modeling the flow patterns in a membrane bioreactor for wastewater treatment tutorial
Old   August 11, 2011, 11:09
Default Modeling the flow patterns in a membrane bioreactor for wastewater treatment tutorial
Shady ENANY
shadyenany is on a distinguished road
Send a message via Skype™ to shadyenany
Hi, my project is modeling the flow patterns in a membrane bioreactor for wastewater treatment using finite volume method. I'm using fluent (workbench) software for the simulation, however i don't have much experience to do this since it's my first time to use fluent. What am asking for is a fluent tutorial which is discussing how i can generate mesh or grid for the reactor i've drawn and how to use fluent for post processing and getting results.
P.s: Notice that what i've done so far is drawing the reactor and imported it into work bence (fluent)..!!
Many thanks,
s.e.
shadyenany is offline   Reply With Quote
Old   September 2, 2011, 04:09
Nicolas
niriosrat is on a distinguished road
The mesh generation depends on what are you trying to model/capture with the CFD. Could you be more specific of what are you planning to do?
niriosrat is offline   Reply With Quote
Old   September 2, 2011, 11:54
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
hi....
please tell me more details...
thanks...
ramakant is offline   Reply With Quote
Old   September 5, 2011, 03:09
Nicolas
Which type of MBR system are you trying to model (i.e. HF, HS, MT)?
Old   September 13, 2011, 11:09
Default Hi
Shady ENANY
Originally Posted by niriosrat View Post
Currently I am working on my project which is modelling of flow patterns in membrane bio-reactor, simply I've drawn a cuboid tank and there are 4 membranes with a stirrer ( rotating mixer) placed inside ,on the base. and I've imported it successfully into the Gambit 3.2.16. the problem is within the geometry decomposition (operation or geometry command button) so I can not build the solid faces however I chose all the edges and faces successfully but it gave me an error saying that can't connect the edges in the wireframe. and If i run the meshing directly it doesn't do the mesh for the whole body but for the base and 1 face only out of the four boundary faces and so can't be imported after in fluent.
Any Ideas or Help Please?!!!!
I'd be very thankful if u can support any dummy tutorials for mixing tank ( multiphase)
Kind Regards;
S.E
Old   September 13, 2011, 11:13
Shady ENANY
I have no idea what are this abbreviations stand for? however it's more simple than that.. am trying to model the flow patterns inside a cuboid tank into 3 phases (water only, water + air, water +air + solid). I've placed 4 membranes and stirrer mixer which is not static part inside the tank.
Old   September 13, 2011, 11:14
Shady ENANY
Originally Posted by ramakant View Post
hi....
thanks...
what details do u require?
Many thanks for reply
Old   September 14, 2011, 02:42
Nicolas
The abbreviations are:
HF: Hollow Fiber, FS: Flat sheet and MT: Multitube
For what I understand you have a problem of importing your geometry in Gambit, that is why you cannot connect the edges (to make the wireframe and form the faces/volumes). Usually, I draw the geometry in gambit if is not too complicate, so I recommend you to do that, so you can avoid this problem or you can look to some tutorial of how to import the geometry into Gambit.
Also, I think is over the top having a stirrer and an air diffuser, as the air will give you enough mixing (airlift) and created liquid recirculation.
You can send me an email with your drawing to
niriosrat "at" yahoo "dot" com
so I can have a look.
Old   September 14, 2011, 15:41
Shady ENANY
Check your email mate .. looking forward to hear from you very soon..
thanks for your help anyways
Old   September 15, 2011, 17:01
Shady ENANY
please just let me know if u've received the email or not?!
thanks
seyedashraf
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 17:12
Boundary condition issue, Modeling flow through spacer filled channel asimsaeed FLUENT 0 August 4, 2010 01:50
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
Flow patterns in a stirred tank Glenn Price Main CFD Forum 13 March 20, 1999 10:16
