3D valve motion but no mesh motion with smoothing
Old   September 16, 2011, 09:11
Default 3D valve motion but no mesh motion with smoothing
Stefan
slaol2 is on a distinguished road
Hi everyone,
I’m working on a valve motion in 3D with only smoothing. The valve movement is relatively small. The mesh consists of hexahedra so I used the TUI command and activated spring smoothing for all shapes. I set the spring constant factor uneven to one. In the dynamic mesh zone panel I defined the fluid cell zones to rigid bodies and the boundaries to stationary, deforming or rigid body type.
The problem is that in the preview mesh motion the nodes on the boundaries don’t move. The cell zones move but the mesh stand still. The smoothing doesn’t work. Has anybody an idea what I didn´t considered? I`ve set “faceted” for the geometry definition of the deforming boundaries. Could that be the problem and is it necessary to use a user-defined Geometry definition?
Thank you.
slaol2 is offline   Reply With Quote
Old   September 22, 2011, 18:06
Default RBF Morph
meb
Marco Evangelos Biancolini
meb is on a distinguished road
If the valve movement is small and you think that can be handled using smoothing you should try RBF Morph http://rbf-morph.com/.
meb is offline   Reply With Quote
deforming, dynamic mesh zones, faceted, mesh, smoothing
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 13:22
unusual mesh motion...............help me out samad87 FLUENT 1 August 10, 2009 01:02
Discrete Values for Mesh Motion UnderwaterAlex CFX 2 February 21, 2008 18:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
