May 23, 2011, 13:40 |
gravity current modelling
N. Aslican YILMAZ
Rep Power: 15 |
Hi!
I'm trying to model a simple gravity current flow Using FLUENT 12.0. It's a very simple one because I'll verify the model results by comparing them with experimental ones. Experimental flume is 4.25 m in length and 0.5 m in depth. first 0.25x0.25 is initially filled with water and at t=0 the lock is opened and gravity flow is recorded. To model this problem I've used. VOF implicit with enabled open channel flow and implicit body force options. For viscous model I've used k-epsilon Realizable with enhanced wall treatment (pressure gradient effects enabled). The problem with the model is water propagates too slow. Could you let me a hand? Do you have an idea what i have done wrong? Thank you so much for your time! |
September 17, 2011, 21:30 |
#2 | |
somayyeh m
Rep Power: 14 |
September 17, 2011, 21:35 |
somayyeh m
Rep Power: 14 |
September 18, 2011, 11:50 |
#4 | |
Hesham Ezz
Rep Power: 14 |
Please I need help in that. Also, I'm searching for any open channel tutorial if anybody knows please send me "ezz.hisham@gmail.com" |
September 23, 2011, 21:02 |
N. Aslican YILMAZ
Rep Power: 15 |
Hi Somy,
Thank you so much for your reply. I see that you've suggested me to give 0 to turbulent viscosity. I'm working with a domain filled with water and mud will have the gravity current in this domain. I still have a very slow propagation. Do you think setting 0 to turbulent viscosity will help? (by the way i'm sorry for late reply) |
September 24, 2011, 03:01 |
#6 | |
somayyeh m
Rep Power: 14 |
yea it will help u. but isnot correct way.i read atticles that simulated this current whit k-epsilon model then turbulent viscosity con't be 0. your current will propagate faster but i don't know velocity, pressure and etc profiles will be corret or no. beacouse of this i earsed my pervious answer. |
September 24, 2011, 03:07 |
#7 | |
somayyeh m
Rep Power: 14 |
Fluent's open chanel tutorial? where are u comfrom? |
September 24, 2011, 09:17 |
Hesham Ezz
Rep Power: 14 |
September 24, 2011, 09:38 |
#9 |
somayyeh m
Rep Power: 14 |
September 24, 2011, 16:20 |
#10 |
Pooya
Rep Power: 15 |
September 24, 2011, 22:43 |
#11 | |
Hesham Ezz
Rep Power: 14 |
my email is ezz.hisham@gmail.com |
gravity flow |
Modelling a gaz-liquid counter current flow? | Arou | FLUENT | 0 | March 9, 2008 06:12 |
Modelling Jet Flow in a current | Adrian | FLUENT | 3 | January 12, 2006 10:42 |
model gravity current and sediment transport | luckyluke | FLUENT | 0 | November 30, 2004 06:24 |
On gravity modelling... | Drona | CFX | 7 | November 22, 2001 10:28 |
Gravity modelling | Drona | CFX | 7 | August 10, 2001 07:00 |
