-   -   moving free surface with VOF (http://www.cfd-online.com/Forums/fluent/92809-moving-free-surface-vof.html)
alilouu September 26, 2011 05:18
hi;
I use the VOF to simulate a fluide with a free surface between two concentric cylinders, the inner is rotating, the outer is stationnary.
the problem is that I can't see the agitation ( the free surface shape) causing by the rotation and the radial .deformation of the inner cylinder.
what i have to do? any help please?
vmeertens September 28, 2011 05:22
did you already try to make an ISO surface? Use "phases" and a value of 0.5 in the ISO surface menu.
The free surface will appear as a surface and is easy to visualize during the post processing (for example with contours -> phase).
m2montazari September 29, 2011 16:19
hi,
did you patch the volume fraction of water in domain and checked the phase contour before iterating?
after solution, what is the shape of phase contours?
yours,
Mohammad
