-   -   node values (http://www.cfd-online.com/Forums/fluent/92924-node-values.html)
bent September 29, 2011 07:31
node values
Hi all
How can I calculate node values from available cell values?
Thank you
m2montazari September 29, 2011 15:56
hi,
if you want node values just for postprocessing, you can use file->export and export node values to a software like tecplot(some softwares has two options of node values or cell values in export window)
yours,
mohammad
bent September 30, 2011 17:17
Re: node values
Thanks Mohammed,
I know that it is possible to export node values. But what i wanted is to use the node values in my UDF program, without manually exporting the node values. So, i wanted to know how I can access node values from within my UDF program.
Best regards
Bent
ian.maes December 3, 2012 09:41
Hi Bent,
I want to do the exact same thing, accessing node values, e.g. temperature and velocity in my UDF. Did you manage to find a solution for this problem?
Thanks a lot,
Ian
