September 28, 2011, 10:04 |
out of memory.malloc_storage-error
dhakshnamoorthy
Rep Power: 14 |
Hi all,
While running the simulation in Fluent 6.3.26. i am getting this error. out of memory.malloc_storage: unable to malloc Reconstruction Phi, size 6403648, t 2, myid 1000000. I have a model which has got upto 8lakhs elements. My system is core 2 duo processor with 4 gig RAM and 130gp free space. Can some one guide me on this please. |
September 28, 2011, 22:21 |
Jack cosby
Rep Power: 14 |
This is a error that you get when your OS Fails to assign the needed memory to fluents processes. This could happen if you have a Superlarge array or reading a case file over and over again via a scheme file, or you just might have very large number of nodes.
Solutions that I know of include:1 Type in fluent.exe -s... and put a large number in front of -s, the value depends on the amount of memory your system can provide try different values keep increasing it until fluent cant open any more and exits with an error. 2- using dynamic memory allocation if you have a UDF, you can find some info on that on the web. try looking for dynamic memory allocation and heap memory allocaion vs stack memory |
September 29, 2011, 16:02 |
Mohammad
Rep Power: 16 |
hi,
did you try a 64-bit operating system? I had ran many huge cases with some millions of cells on them and no error! yours, mohammad |
September 30, 2011, 09:34 |
dhakshnamoorthy
Rep Power: 14 |
failed of allocate, fluent 6.3.26 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
