How to apply pulsatile velocity in boundary condition?
Old   September 29, 2011, 00:34
Red face How to apply pulsatile velocity in boundary condition?
Sama
Sama is on a distinguished road
Hello. I am simulating aorta with aneurysm ( locally dilated aorta) . for velocity boundary condition I have problem. velocity is pulsatile, it is changing during one cardiac cycle. I know how to apply constant velocity boundary condition, but I am not able to do it for a pulsatile velocity. I would appreciate you if you guide me with this problem.
Sama
Sama is offline   Reply With Quote
Old   September 29, 2011, 04:55
engin leblebici
engin is on a distinguished road
For solution to your problem, you could use transient boundary profiles if your boundary conditions are not spattially varying. I think they are not for your case. Check section 7.1.9 of the fluent user guide for more info. If spattially varying BCs are needed, you should use UDFs.
Regards
engin is offline   Reply With Quote
Old   September 29, 2011, 13:00
Sama
Thank you very much, dear engin. yes it is not spatially variable,so I can use transient BC.I have to go to manual for precise underestanding of it I just started learning ansys Fluent 2 days ago.
Old   October 2, 2011, 16:19
behnam
Behnam Ghadimi is on a distinguished road
Originally Posted by engin View Post
Regards
hi engin
you are write, but i think you can use profile for some spattially varying case. you must insert the location of any node in the global coordinate system and then insert the velocity of that nodes. such as
((P_inlet radial 12)
(r
0 .05 .1 .15 .2 .25 .3 .35 .4 .45 .5 1.5)
(pressure
4340 4280 4060 3720 3100 2780 2370 1890 1410 740 0 0)
you insert 12 point velocities in radial direction and fluent interpolate velocities for nodes which lie between this nodes.
or for time changing variable:
((sampleprofile transient 3 0)
(time
1
2
3
(u
10
20
30
Behnam Ghadimi is offline   Reply With Quote
Old   October 3, 2011, 10:05
engin leblebici
Dear Benham Ghadimi,
I said if not spatially varying for both spatially varying and time varying BCs as the simulation is transient. Profile file format is not suited for both spatially and time varying BCs. For this kind of BCs, you should use UDFs or periodic BCs.
Old   October 4, 2011, 07:09
behnam
dear engin,
you are write, i misunderstanded your purpose, but i think it's possible to combine time and space variation in profiles, i don't use this but i think it must be possible, if else please tell me.
but as you said UDF is a good way for this purpose.
thanks a lot
Behnam Ghadimi
Old   October 5, 2011, 15:50
Mohammad
m2montazari is on a distinguished road
dear sama,
take a look at http://www.cfd-online.com/Forums/flu...nlet-tube.html
it may help.
yours,
mohammad
m2montazari is offline   Reply With Quote
Old   October 7, 2011, 07:44
engin leblebici
Dear Behnam Ghadimi,
As I said before profile format is not suitable for spatially and time varying BCs. But if the BC is periodic you could use periodic BCs. So it is not possible with profiles if the BCs you are going to use are varying with both time and space (irregularly). Take a look at the FLUENT manual about profiles. There must be a warning about that if I remember correctly.
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
how to apply cauchy type boundary condition in fluent aksrun FLUENT 0 January 30, 2010 08:07
Plot a graph of velocity & boundary condition problem wanie Fluent UDF and Scheme Programming 0 December 11, 2009 10:40
UDF-Time-dependant velocity inlet Boundary condition xavi FLUENT 0 June 15, 2009 12:16
Inlet velocity boundary condition in Polyflow ZHANG Xian-Ming Main CFD Forum 0 October 18, 2006 21:06
