Tetrahedral vs Polyhedral
Old   October 4, 2011, 14:53
Default Tetrahedral vs Polyhedral
rofluent
Rohini is on a distinguished road
Hi all,
I am trying to validate the efficiency of polyhedral meshes in capturing wall shear stress in blood vessels. For this, I create tetrahedral meshes using gambit and convert them to polyhedral using fluent. However, when I am comparing the WSS distribution between polyhedral and the original tetrahedral meshes, the polyhedral seems to underestimate WSS. Has anyone had this problem before? Your suggestions are appreciated.
Thanks
Rohini is offline   Reply With Quote
Old   October 4, 2011, 16:46
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by Rohini View Post
Hi all,
Thanks
I also had few investigations concerning WSS in human tissues and upon my experience non of these types were good choices. In my case, WSS was very sensitive to boundary element especially smoothness of grid lines on boundaries. Finally I could validate my numerical results just with proper mapped hexahedral cells with smooth grid lines. I think the main issue of other element types is normal vector of boundary faces which may deviate from origin one. Another tip, note that in many softwares like FLUENT (at least in 6.3 ver.) wall traction is reported instead of WSS, so if you want tangential stress you'll need some post processing steps. Hope that help you.
Bests,
Amir
Amir is offline   Reply With Quote
Old   October 4, 2011, 16:55
rofluent
Hi Amir,
Thanks for your response. What exactly do you mean by smoothness of grid lines on boundaries? Is it the boundary layer thickness you are talking about? Also, I am using fluent 12.1 and I am able to visualize Wall shear in fluent itself. However even velocity distribution for some planes that visualized seemed to be lower in polyhedral case.
Old   October 5, 2011, 09:20
Amir's Avatar
Amir
No, I meant that slope of grid lines should be continuous @ boundaries when we compare structure grid @ boundaries. (something when you use multi-zone topology, this feature may occur). Unfortunately, wss results for any pave topologies @ boundaries were not satisfactory.
I know that, I just wanted to warn you about a bug which I saw in FLUENT ver 6.3 and I'm not sure it's removed in new versions or not. You can also see WSS in 6.3 versions but it's wall traction not wss!
Amir
fluent, polyhedral, tetrahedral meshing
polyhedral cells bill Main CFD Forum 10 March 11, 2014 06:52
[Technical] is possible to do tetrahedral or polyhedral mesh OpenFoam?? Ale_galleria OpenFOAM Meshing & Mesh Conversion 2 January 11, 2011 06:06
[snappyHexMesh] is possible to do tetrahedral or polyhedral mesh using snappyHexMesh?? Ale_galleria OpenFOAM Meshing & Mesh Conversion 1 September 15, 2010 12:00
Polyhedral in parallel drdr18 FLUENT 5 April 3, 2009 17:56
Numerical error in tetrahedral cells Sam Main CFD Forum 1 February 14, 2009 14:51
