Home > Forums > FLUENT
some problem in the UDS
Old   October 11, 2011, 04:55
Default some problem in the UDS
Yu-Pei Chen
ypchen is on a distinguished road
hi, everybody, I create a UDS as follow : d(phi)/dt=m, where phi is scalar variable, and m is my source term : m = C*exp(-E/RT)*log(p/p_eq)*(D-phi), where C, E, R and D are constant, T is temperature, p is pressure and p_eq is equilibrium pressure (function of temperature). I wrote a udf code below :
#include "udf.h"
#include "mem.h"
#include "math.h"
#include "stdio.h"
#define R 8.314
#define E 21180
#define C 59.19
#define SAT_DEN 7259
#define A 17.61
#define B 3704.6
DEFINE_ADJUST(absorption,d)
Thread *t;
cell_t c ;
real p_g ;
real P_eq;
real m ;
thread_loop_c(t,d)
begin_c_loop(c,t)
real tem = C_T(c,t) ;
p = C_P(c,t)+101325;
p_eq= 1000*exp(A-(B/tem));
m = C*exp(-E/R*tem)*log(p/p_eq);
C_UDMI(c,t,0) = m ;
end_c_loop(c,t)
DEFINE_SOURCE(uds_source,c,t,dS,eqn)
real source ;
source = C_UDMI(c,t,0)*(SAT_DEN-C_UDSI(c,t,0));
return source ;
my problem is when I simulate the UDS with C-E, M-E and E-E, the result is not good, because the phi's distribution is very uniform, but I expect its distribttion are respect to the location, it should not be uniform, can anybody help me ? thank you !
ypchen is offline   Reply With Quote
Old   October 11, 2011, 05:27
Amir's Avatar
Amir
Amir is on a distinguished road
1- your source term is a function of UDS, so you can define it's derivation with respect to your UDS to enhance stability.
2- Did you disable convective term of UDS equation while activation?
3- Did you set diffusion coefficient to zero?
4- According to UDS equation, the phi variable would be \rho * C; which C is your UDS; if your base fluid density is not equal to 1, you have to change your source equation respectively. (BC should be changed)
Bests,
Amir
Amir is offline   Reply With Quote
Old   October 11, 2011, 09:24
Yu-Pei Chen
hi, thank for your reply, Amir
-------------Ok , I'll try .
-------------yes, I set it to be "none" in the panel.
-------------yes, in the Material setting.
------------I use the macro "DEFINE_UDS_UNSTEADY" to set the unsteady term, and let the rho equal to 1.
my simulation can run when the udf code is used, but the result seems not good ....
Old   October 11, 2011, 15:51
Amir's Avatar
Amir
Ok, it doesn't need any other special settings; it can be implied form results that your source term is large! Maybe its better to check dimension of constants ....
Bests,
Amir
Old   October 11, 2011, 22:00
Yu-Pei Chen
Thank you, Amir. I will keep checking my code.
Thread Tools
Trackbacks are On
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 09:28
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
