Oxy-Fuel combustion dasac failure
1 Attachment(s)
I´m trying to simulate a Oxy-Fuel combustion with fluent, but when I try to ignite the mixture I get a lot of failures: "dasac failure at Temperature = XXXX.XXX K: Continuing... ", where XXX.XX represents the respective temperature. I´m using a pressure based, coupled solver and the EDC combustion model. I have changed the turbulence model a few times, changed to laminar ED with stiff chemistry solver and changed to the pressure based solver, but it´s always the same: dasac failure. Increasing and decreasing the isat table size and changing to direct integration is meaningless.. I´m using the extended Johnson & Lindstedt reaction mechanism by Frassoldati (the mechanism is attached). I ignite the mixture with 2000-2500K. If someone has experience with this problem, or an idea about fixing it, helping me would be very nice. Best regards, Patrick |
No idea? Does someone know other (under 10-15 species) mechanisms for simulating oxy-fuel combustion?
Hi Pat84, have you figured out your problem? I encountered this dasac failure recently and I tried several ways but nothing works.
Increasing the ISAT error tolerance (up to 1e-2) may help but be aware of accuracy of your result.
