Home > Forums > FLUENT
Temperature problem
Old   October 15, 2011, 10:48
Question Temperature problem
Shubhankar
shubhankar.kulkarni55 is on a distinguished road
Hi everyone!
I am having a problem of temperatures shooting up to a very high value after specifying 'source terms' or 'heat flux' value. The calculated values are verified. I also tried reducing the source term values, still the temperatures are not decreasing. Any suggestions?
Thanks!!
shubhankar.kulkarni55 is offline   Reply With Quote
Old   October 17, 2011, 06:11
sabin's Avatar
sabin mathew
sabin is on a distinguished road
Send a message via Skype™ to sabin
Do following checks
1)make sure that units are consistent.
2) Check thoroughly value of Cp, k
3) If there is phase change in actual case apply 'limit' at that temp in Fluent.
Fluent will obey energy balance pretty accurately ..All the best
sabin is offline   Reply With Quote
Old   October 17, 2011, 06:50
Post Thanks!
Shubhankar
Thanks a ton for your reply.
I am using the standard material database available in Fluent and also there is no phase change in the problem. I have tried reducing the source term value by 10 times, still the temperatures are not coming to be accurate! Please let me know if there can be any other problem!
Thanks again!
Old   October 17, 2011, 07:02
sabin's Avatar
sabin mathew
Fluent database properties are defined for NTP. If your operating condition is different properties will be different. Check for that.
Thread Tools
Trackbacks are On
PorousMedia Problem with Temperature Distribution pawan OpenFOAM Running, Solving & CFD 2 August 2, 2015 23:08
temperature gradient problem in udf Souviktor Fluent UDF and Scheme Programming 3 July 11, 2015 15:49
problem to export a temperature profil hittie FLUENT 0 May 4, 2011 19:09
a problem with temperature depending properties anijdon OpenFOAM 2 March 29, 2011 17:46
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 05:56
