-   -   shock wave in very high pressure gradients (http://www.cfd-online.com/Forums/fluent/93711-shock-wave-very-high-pressure-gradients.html)
ndabir October 24, 2011 13:42
Hello all,
I want to simulate a shock propagation induced by a very high pressure gradient of inlet and outlet (around 1 Giga Pa).
I am using an explicit solver with first order upwind and with time steps of around 10^(-10) since I just need to model a very short time after shock initiation.
The problem is when this pressure gradient is around 10 MPa, i will have very good results but as I change it to higher pressures, it gives me these errors:
Error > (greater-than): invalid argument [2]: wrong type [not a number]
Error Object: -1.#ind
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate
Error Object: #f
these errors appear after one iteration! does any body have any idea?
is fluent capable of simulating this high pressure gradients?
thanks,
cartman October 24, 2011 14:17
I'm not kind of expert but...
1. did you checked solution limits?
2. if you reduce under-relaxtion coefficients, it might be...
3. mesh can occur problems
good luck :D
cartman October 24, 2011 14:19
oh dear lord..
how can I delete this text?
ndabir October 29, 2011 13:54
I have checked all of this but this error appears at the first step. any idea?
immortality February 26, 2013 19:48
how did you solve the problem?
