August 10, 2010, 01:38 |
floating point error!
hi every body !
I made my geometery in gambit(2 part)! then I merged them, and read them in fluent! when I run this file I get only these, nothing else!!! iter continuity x-velocity y-velocity z-velocity k epsilon time/iter reversed flow in 1440 faces on pressure-outlet 11. turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 64505 cells 1 1.0000e+00 2.2368e+04 1.1092e-07 4.1418e-01 9.2458e+08 9.6332e+16 0:19:56 299 reversed flow in 501 faces on pressure-outlet 4. reversed flow in 203 faces on pressure-outlet 11. turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 308949 cells Error: Floating point error: invalid number Error Object: () what is this error?????????? is there anybody to help me? please! I look forward 4 ur answer dear. |
February 8, 2012, 03:17 |
Floating error and Same results u r getting
Rep Power: 14 |
Hello
i am getting floating error:invalid number. I am working on train travelling in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com thanks |
February 8, 2012, 03:58 |
Rep Power: 20 |
check your boundary conditions and specify correct pressure, velocity values. You get floating point error when some number gets divided by zero durning your iterations. Hope it helps
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Floating point Error message | Jonathan | FLUENT | 2 | January 16, 2007 04:07 |
