How to get "Fully developed flow" at pipe inlet without changing length
Old   November 2, 2011, 16:22
Default How to get "Fully developed flow" at pipe inlet without changing length
Naser Imran Hossain
nihossain is on a distinguished road
The title of the post pretty much sums up my problem. How do I get a fully developed flow at the pipe inlet in FLUENT without changing the length of the pipe from GAMBIT? Is there a specific "boundary condition" setting that I'd have to apply? I remember someone saying this in another thread:
If you want a fully developed flow at inlet, you should firstly run another simulation, in which you impose periodic conditions or you have a sufficiently long developing region. Once you obtain a developed flow at the outlet of this system, you can write a profile (Write > Profile) for your velocity and then read it in your final case (Read > Profile). When setting boundary conditions, you'll see that this profile will be available ("constant" tab). See FLUENT User's Guide chapter 4.6 for some more deta
Is that the only way of doing this? Or is there another easy way out?
Thanks. Some prompt help will be really appreciated.
nihossain is offline   Reply With Quote
Changing inlet conditions without starting again Conflate OpenFOAM Pre-Processing 3 April 25, 2022 08:19
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 09:02
inlet velocity profile for fully developed turbule pankaj saha Main CFD Forum 4 August 24, 2007 16:53
Changing inlet mass fractions of CH4 and O2 Prateep Chatterjee FLUENT 4 June 13, 2002 12:06
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 21:28
