November 10, 2011, 02:34 |
UDF compilation error solved
Laurent B
Rep Power: 16 |
I spent some times after i get this error message in fluent while compiling :
# Generating udf_names.c because of makefile UDF_V7_Fouling.obj udf_names.c udf_names.c(6) : error C2449: found '{' at file scope (missing function header?) udf_names.c(32) : fatal error C1004: unexpected end-of-file found Strangely it works well in interpreted mode. It was due to the curly-bracket positionned at the end of Define_Property DEFINE_PROPERTY(water_viscosity, cell, thread) { If the curly-bracket is on the next line the compilation is OK : DEFINE_PROPERTY(water_viscosity, cell, thread) { Regards, Fluent 13.0 win64 & 12.1 x86 Microsoft Visual C++ 2010 Express |
November 10, 2011, 05:46 |
Rep Power: 16 |
It is because fluent uses "sed" to extract the function names.
The definition should match the regular expression pattern: Code:
^DEFINE_\([_A-Z]*\)( *\([_a-zA-Z0-9]*\).*) |
Display Modes | |
UDF compilation problem on Linux System | Nitin Pathak | Fluent UDF and Scheme Programming | 6 | September 29, 2018 21:26 |
UDF compilation error | Szabolcs Varga | Fluent UDF and Scheme Programming | 4 | September 14, 2015 06:27 |
problem with compilation udf about droplet collision (DPM) | Jaskull | Fluent UDF and Scheme Programming | 0 | November 7, 2011 15:09 |
UDF compilation problem -- "undeclared variable" | Henrik Ström | FLUENT | 1 | September 21, 2005 06:25 |
Compiled UDF / Compilation problem | mikhail | FLUENT | 1 | October 13, 2000 07:12 |
