Home > Forums > FLUENT
grid adaptation
Old   November 14, 2011, 02:33
Default grid adaptation
Hamid
L. Hamid is on a distinguished road
My case is studding the pressure drop thought the geometry. this geometry consist of one inlet with specific mass flow and this mass flow divided into seven outlets.
I am trying to find my grid independent solution using grid adaptation. would you please give me some suggestions on this. how should I start: adaptation with static pressure gradient or velocity gradient adaptation?
thanks
L. Hamid is offline   Reply With Quote
Old   November 14, 2011, 12:33
raj
raj.cfd is on a distinguished road
Hi, Before starting grid adaptation, you really need make sure, if your solution is dependent on the grid, since it takes enormous computational resources for 3D grid adaptation.. I hope your geometry looks simple with single inlet and seven outlets. You can probably generate a good quality mesh ( look for skewness, AR, OQ, EQ, and ofcourse calculate first cell distance / y+ value) . Simualte until convergence, try not just using convergence criteria, but look for mass, heat, and flow inbalance along with monitoring the relevant parameter at the area of interest until the change is minimal. Next incase you think, the results are not pretty convincing, you can go ahead and adapt regions of interest.
raj.cfd is offline   Reply With Quote
Thread Tools
Trackbacks are On
No grid adaptation Pimmie80 FLUENT 1 September 21, 2010 08:35
grid adaptation for better convergence. co2 FLUENT 9 April 2, 2004 14:08
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
floating point error during grid adaptation Nurul Murad FLUENT 2 September 5, 2001 19:15
