Particle Radiation Interaction
Old   November 16, 2011, 04:21
Default Particle Radiation Interaction
Michal
Twix is on a distinguished road
I’m modeling tangentially fired boiler and everything is fine, my solution is converged but when I try to include particle radiation my solution starts diverge. My turbulence model is standard k-e and radiation model is DO. I use species transport, volumetric reactions and eddy dissipation. To inject particles to the domain I use DPM and for particle combustion kinetics/diffusion-limited model. My question is: what is the best way to include particle in radiation process? I tried to increase values of Particle Emissivity and Particle Scattering Factor but number higher than 0.05 cause solution divergence while recommended values are respectively 1 and 0.9.
I would be grateful for any suggestions.
Regards
Twix is offline   Reply With Quote
Old   November 20, 2011, 07:29
xrs333
xrs333 is on a distinguished road
Hi, Twix,
How did you define the saturate pressure of the droplet material? Did you use temperature dependent function? It is very important.
xrs333 is offline   Reply With Quote
Old   November 21, 2011, 04:52
Michal
Hi xrs333,
I use wet combustion mode to include moisture contained in coal particles and by default saturation vapor pressure is set as piecewise-linear temperature dependent. In my case moisture content is small so impact on simulation will be also small (it delay devolatilization initiation a little and add some H20 vapor). If you modeling droplet vaporization or liquid fuel combustion it is value used to obtain driving forces of evaporation process but I don’t have experience in that kind of simulation so I can’t help in details.
Regards
Old   September 23, 2014, 03:48
Default solved?
Joakim M. Johansen
jmjohansen is on a distinguished road
Did you find a solution to this? I am experiencing the same difficulties when modeling biomass devolatilization in laboratory furnaces.
jmjohansen is offline   Reply With Quote
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. FLUENT 0 September 14, 2011 15:40
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
About particle radiation kris Siemens 0 July 31, 2005 20:45
interaction time between particle and eddies Steve FLUENT 0 April 10, 2001 18:17
Interaction of Radiation with Turbulence Aristide Mbiock Main CFD Forum 1 December 16, 1998 16:04
