plot Pressure drop in pipe
Old   November 17, 2011, 17:18
Default plot Pressure drop in pipe
Monty
monty_p20 is on a distinguished road
Hello everyone,
I want to know how to plot pressure drop (P_inlet - P_outlet) vs iteration in pipe. Using monitors at surfaces (at inlet and outlet) I have got the pressure values per iteration. How should I plot their difference vs Iteration. Can I also do it in CFD postprocessor usng Expression.
Thanks for giving your time.
Regards,
Monty
monty_p20 is offline   Reply With Quote
fluent, fluent - udf
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 09:33
pressure drop calculation multi-inlet-outlet syst. timmyy FLUENT 1 April 24, 2007 06:03
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Pressure drop in periodic turbluent pipe flow lou FLUENT 0 September 21, 2005 00:58
