Home > Forums > FLUENT
isat terminated
Old   November 22, 2011, 22:52
Default isat terminated
San Siro
San Siro is on a distinguished road
When I used the laminal finite-rate model to simulate a reaction involves both volumetric reactions and wall surface reactions,I selected the Two-Step Solution Procedure.I begin by solving the flow, energy, and species equations with reactions disabled.When the basic flow pattern has been established,I enable the reactions and continue the calculation.
Then fluent gives the error message:
Error: Non-physical Specific Heat = 0.000000e+000.
Error Object: ()
I ignore the message and continue to calculate,fluent gives the following error message:
Error: isat terminated.
Error Object: ().
This problem has troubled me for a long time.Is there any suggestions how can I solve this problem and continue my calculation.
Thank
San Siro
San Siro is offline   Reply With Quote
Old   August 7, 2014, 10:58
Bruna
BMancuzo is on a distinguished road
Have you found the solution for your problem?
I'm trying to set up a chemical reaction but this message keep appearing.
Thanks in advance,
BMancuzo is offline   Reply With Quote
Thread Tools
Trackbacks are On
Isat table antallo FLUENT 0 May 19, 2011 06:20
Isat and OnlineLibrary Alish1984 OpenFOAM Running, Solving & CFD 0 February 28, 2011 09:35
Isat and Online library Alish1984 OpenFOAM Programming & Development 0 February 28, 2011 09:30
run terminated with overflow error maz.mahzari CFX 1 February 18, 2010 15:08
ISAT error and ddasac failure Stephen Mattick FLUENT 1 July 18, 2003 13:57
