-   -   Surface Nusselt Number tooooo high (http://www.cfd-online.com/Forums/fluent/94878-surface-nusselt-number-tooooo-high.html)
kamran651 November 29, 2011 02:46
Hi brothers,
I have designed a 1m length rectangular 2D cylinder-type model with. the inlet is 0.125 m on the top, and the flow is in the -Y direction and moving along the x direction after impinging on the wall below..my question is i want to study the heat transfer and Surface Nusselt Number on the impinging wall, i am using 2ddp realizable k-e model and set all the values correctly..my concern is
>>> the Surface nusselt number on the impinging wall is coming out to be in the range of 5000, whereas as previous studies or comparison, it should come out to be between 120-150.
anyone has any idea.where i am going wrong.???
Help highly appreciated
bets Regards.:confused:
CFDaniel January 9, 2012 02:14
As far as I know, try to change the reference values given in the reference values menu. It doesnt need to start the simulation again. Those values only work for postprocessing.
You may take:
D as your hydraulic diameter
T as your reference pressure
Check it
I hope you find the solution. Be careful with those values you choose, because they can change considerably Nusselt values.
kamran651 January 9, 2012 06:40
Thanks Bro...
Yes you are right..i was not setting the reference values correctly which are used for post processing..i figured that out...
Thanks Bro
Kamran.
