December 1, 2011, 09:51 |
Nr cells thin thickness
Flavio
Rep Power: 15 |
Hi everybody,
I'm working on a volume very thin, 1 mm thickness, with porous zone boundary condition imposed (the component is a burner of a boiler). The lenght of the global domain is 300 mm, so this component is very critical and I have to decrease the number of cells to obtain a faster resolution in Fluent. Do you think that 3 or 4 cells along the thickness are enough to obtain an accurate solution? Or I should put 8-10 elements? This parameter is very important to decrease even the skewness, so the smaller, the better! Thanks in advance |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
