Nr cells thin thickness
Old   December 1, 2011, 09:51
Default Nr cells thin thickness
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi everybody,
I'm working on a volume very thin, 1 mm thickness, with porous zone boundary condition imposed (the component is a burner of a boiler).
The lenght of the global domain is 300 mm, so this component is very critical and I have to decrease the number of cells to obtain a faster resolution in Fluent.
Do you think that 3 or 4 cells along the thickness are enough to obtain an accurate solution? Or I should put 8-10 elements?
This parameter is very important to decrease even the skewness, so the smaller, the better!
Thanks in advance
Bionico is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
