November 29, 2011, 11:12 |
Simple 3D IC two stroke engine simulation
Darren Cam
Rep Power: 14 |
Hi people,
I am trying to model a 3D IC two stroke reciporacting engine cylinder for my final year thesis. Therefore I do not have the added complication of overhead valves. However, I am finding great difficulty in achieving the dynamic mesh. 1. I learned that layering should suffice and remeshing and smoothing are not necessary because I havent got any protruding valves. Is this true? 2. I was doing the 3D adiabatic compression tutorial however it includes remeshing and smoothing in it and it got me confused. 3. I succeded in achieving piston zone motion in the way that I want it however when I simulate a mesh motion, I did not succeed. 4. Are there any particular important things one has to make sure he does in the geometry and meshing stages? I'm sorry if it sounds like I did not make a great effort in trying however I am totally confused at the moment and if anyone can offer me some advice it would be greatly appreciated. Many Thanks, Darren |
December 3, 2011, 08:31 |
reply
hi friend
1. layering should be used when there is an hex mesh. 2. remeshing should be used when you are using tet mesh. however smoothing is common for both. 3. try to go with correct value for input |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 09:46 |
diesel engine simulation | babusidharthan | Main CFD Forum | 2 | October 6, 2010 04:09 |
IC Engine simulation in Fluent | Ravi Kiran | FLUENT | 0 | March 5, 2006 23:48 |
Engine simulation (seeking help with method to use) | Geoff Rathbun | Main CFD Forum | 4 | April 13, 1999 14:19 |
Question concerning about the flow simulation of a fan in an engine room. | ghlee | Main CFD Forum | 3 | October 21, 1998 07:05 |
