Why is Fluent unable to deal with my model at the micron scale?
Like Tree1Likes
  • 1 Post By Amir
Old   December 8, 2011, 03:47
Default Why is Fluent unable to deal with my model at the micron scale?
dixylo is on a distinguished road
My model is a micro turbo rotor spinning in a cylindrical wall. When I scaled the grid by setting the scale factors of xyz to be 0.00001 or lower, the iteration would stop in one step, saying "solution is converged"
At first i thought something was wrong with my grid and settings, so i created a cylindrical pipe model where liquid flows in with a speed magnitude equal to that of the radius through the bottom and out through the top, but this model has the same problem that when the scale factors of xyz are lower than a certain value (0.0009 here), the iteration stops within one or a couple of steps.
however, what has puzzled me is that when the scale factors are greater than a certain value (1e-5 for my rotor model and 0.0009 for the pipe one), the problem doesn't show up and Fluent gives a good solution.
so can Fluent deal with models as small as tens of microns?
dixylo is offline   Reply With Quote
Old   December 8, 2011, 05:04
Amir's Avatar
Amir
Amir is on a distinguished road
Did you disable convergence criteria in "solve->monitor->residual" ?
It better to use double precision version for your purpose and also, you can change length dimension to "mm" for example but as you said, this problem may exist even in double precision solvers if the variables would be in the order of round off error which is about 1.0e-16. As there are many simulations with FLUENT for micro channels in literature, I don't think that this can make any issue for your case. But if you couldn't solve this problem, maybe a dimensional analysis can help.
Bests,
Amir
Amir is offline   Reply With Quote
Old   December 8, 2011, 13:39
Smile
Originally Posted by Amir View Post
Bests,
I didn't disable convergence criterion (I kept it as "absolute"). Most settings were kept as default. I tried double precision solvers as soon as i met this problem, but they didn't work either. As you said, there are many simulations with FLUENT for micro channels in literature, this is what has puzzled me. If you are interested in this problem and will spend a little time, you may create a similar model, for instance, a cylinder with a height of 5 and a radius of 1, and the bottom as VELOCITY-INLET boundary type, the top as OUTFLOW. Scale it with scale factors 1e-6. Other settings can be done as they should be. And i think you would probably see "solution is converged" in one iteration step. anyway, thank you for your reply and your suggestion.
Old   December 8, 2011, 14:31
Amir's Avatar
Amir
I meant toggle off "check convergence" in "solve->monitor->residual"; in this manner you never face "solution is converged"!!! just let it continue to iterate.
Bests,
fruitkiwi likes this.
Amir
Old   December 8, 2011, 23:39
Smile
Bests,
Sorry, I'm a newb so i didn't quite understand what you'd meant as well as some of those variables and settings. Your suggestion did work, and i think what i should do now is optimize the grid. Thank you very much for you kind help.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Can FLUENT model flashing liquids? SWK FLUENT 9 June 22, 2017 01:17
self-built model embeded in FLUENT Jiedong FLUENT 0 January 22, 2009 02:57
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
