May 13, 2010, 15:27 |
plot bulk temperature of fluid
mohammad
Rep Power: 16 |
Dear all
we can get bulk temperature in Report>Surface integrals:change report type from Area to Facet average. with this way i get bulk temperature in inlet or outlet or... The problem is how can i plot bulk temperature in x-direction? There is no bulk temperature in xy plot!! Is there any way to plot and write bulk temperature in x-direction? thanks |
November 11, 2011, 11:54 |
Rep Power: 14 |
hi mohammad,
there is no direct way to calculate bulk temperature in x-direction, you may creat some surfaces,then in costume field functions tab(in definition tab) make Velocity*Temperature function,in Report>Surface integrals use integral or sum report(depends on your precision) for both Velocity and your Velocity*Temperature function on each section; by diveiding these two quantity,you will have bulk temperature in each section, then u can use curve fitting for your x-bulk temperature |
December 9, 2011, 00:05 |
Shashank
Rep Power: 15 |
Where to create surfaces? At some distances from the wall you mean?
December 11, 2011, 09:33 |
#4 | |
Rep Power: 14 |
iso surfaces are cross-sections where you want to calculate bulk properties,so they are perpendicular to your wall |
December 13, 2011, 15:37 |
Shashank
Rep Power: 15 |
How to create surfaces using TUI or journal file. Please help. The FLUENT text command list does not give any examples.
how to create a temperature dependant fluid | Amy | CFX | 4 | October 18, 2009 19:30 |
Solid Surface and Fluid Results Plot | CK | FLOW-3D | 2 | November 12, 2008 00:32 |
Fluid Vs. Wall Temperature | Jack Smith | FLUENT | 5 | January 25, 2006 11:42 |
Plot temperature vs time for a defined point | FREDERIK | FLUENT | 0 | August 26, 2005 05:49 |
bulk temperature .. Urgent !!! | yogesh | FLUENT | 0 | February 22, 2005 00:58 |
