December 9, 2011, 05:55 |
Problem in interfacing
Vaibhav Rai Khare
i have prepared a model in Gambit n applied interface command on it..after exporting in fluent i did grid interfacing of the interface..but heat transfer is not passing the interface..the upper side of model is being unaffected..is there any other process which i left during processing or initialization????
December 9, 2011, 07:01 |
Vaibhav Rai Khare
Thnkx amir, but i have already done that but there is no change on upper side of interface.
December 10, 2011, 01:28 |
deewakar
hi,
What I perceive from your statement is that you have 2 regions say a solid and liquid and you want to study the temperature etc profile in them.But the way you are proceeding , u are getting profiles independent of each other.I n short you want to carry out conjugate heat transfer analysis. If that is the case do the following: when you are making geometry, select the parts (or zones , fluid and solid to be studied in ur case )and convert them in to one body by selecting make new part. after that when u mesh and all it will show the desired results. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
