December 10, 2011, 05:19 |
Cooling slots
Pradeep
I am working on cooling a cuboid with slots drilled along its breadth. So i made a 2D version and meshed it in Gambit. It basically has SOLID portion then a thin slot for the cooling fluid and then again a SOLID portion. This is exposed to a flow of hot FLUID. Now the first SOLID portion exposed to the hot gas gets heated up but the second SOLID portion (the one after the cooling slot) does not.What I think is its because heat is not getting conducted into the second portion from the first.
Is there any way to include conduction between the two SOLID parts in FLUENT?? |
About Cooling channel | alefem | FLOW-3D | 1 | May 28, 2010 11:15 |
Regenerative cooling nozzle. | Brian | Fidelity CFD | 3 | September 1, 2005 08:53 |
Regenerative cooling rocket engine | Brian | Main CFD Forum | 0 | November 12, 2003 06:59 |
Regenerative cooling nozzle. | Brian | Main CFD Forum | 0 | November 10, 2003 01:11 |
Passive cooling system for batch reactor | Darek | Main CFD Forum | 0 | September 30, 2003 05:06 |
