is Transient solution really needed for Propellers?
Old   December 20, 2011, 14:54
Default is Transient solution really needed for Propellers?
Emre G
emreg is on a distinguished road
I am solving thrust and torque on contra-rotating propellers ( there are two propellers rotating in counter sides)
Do I actually need a transient solution or Sliding mesh+steady state solver is enough?
thanks.
emreg is offline   Reply With Quote
Old   December 22, 2011, 16:56
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
thanks.
Isn' t the moving mesh approach intrinsically transient? If you want/have to use a steady solution you might try the moving reference frame approach, but with propellers with few blades and/or high interferences between each other (thinking about your counter rotating case) you will loose some accuracy and won't capure certain phenomenas wich might at the end give out meaningless results.
My two 0,02€
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   December 24, 2011, 01:25
Far
Sijal
you should go for the multiple reference frame approach first (steady state) and if not satisfied then go for the sliding mesh (transient). Keep in mind for sliding mesh to give you accurate results you may need big machines !!!!!!!
Old   December 25, 2011, 16:20
Emre G
yes huge machines actually
how about the size of time step, do u have an idea about its proper scale?
Old   December 25, 2011, 22:43
Far
Sijal
you should be able to calculate it from the pitch and rpm. checkout tut on turbo-machinery in CFX
Old   February 9, 2022, 22:10
Nathan CHEN
Saintree is on a distinguished road
Hi Emre
Have you tried the transient sliding mesh on this contra-rotating propeller? May I ask how you dealt with the interface between the contra-rotating zones?
For my case, if I set a pair of contra-rotating zones using mesh motion, the calculation would break immidateley and said "Node 1: Process 9092: Received signal SIGSEGV".
Do you know the reason and how to solve this?
Thank you very much.
Nathan
Saintree is offline   Reply With Quote
Old   February 9, 2022, 23:10
Emre G
Originally Posted by Saintree View Post
Hi Emre
Nathan
Yes i overcomed this issue ten years before
Please check your interface surface mesh. İt should be unconformally mismatched or a very scewed mesh cell is encountered. And please start with MRF solution, if you still get same error check again interface surfaces if they have different diameters or have a big gap between them.. this would be a mesh issue !
Old   February 9, 2022, 23:20
Nathan CHEN
Thanks Emre, and I will try it as you suggested.
I didn't notice that it has been more than ten years. It's really kind of you for replying me.
Thank you again and wish you all the best.
Nathan
Transient solution not oscillating paul83 CFX 20 April 23, 2015 18:25
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Transient conduction possible in fluent? jlefevre76 FLUENT 2 February 5, 2013 09:53
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
difference between false and true transient mahesh prakash Main CFD Forum 1 January 21, 1999 13:45
