Axis B.C in multiphase problem
I am going to simulate a drop in a tank (2 phases), using VOF model. my geometery is 2D with a axis, as shown in the figure and I impose the initial position of the drop using UDF, but I'm getting error when I try to solve the problem in Fluent. I think the problem arise from the axis BC. and its portion with different phase. Does anybody have any idea how to fix it...? Thanks... http://s2.picofile.com/file/7221308381/Untitled_1.jpg |
hi
Try to patch the region with the liquid instead of giving the udf.
SHK |
Thanks... |
take axis as a single axis and then try it.Dont divide it into zones.
I defined a region in adopt window in Fluent and patched it, also my axis is composed of only one segment. but I still get the AMG Sokver Error.
I think the problem is originated from axis BC itself because I get the same error even without any drop defined in the domain (with only one phase in VOF), whereas I have no problem when I change the axis into wall.
hi
try to the simulation with complete bubble in the center with walls on both the side. SHK |
