strange massage
Old   December 20, 2011, 15:35
Default strange massage
naor
naor is on a distinguished road
i use an Eulerian model, and when i try to increased the volume fraction (B.C->velocity inlet-> volume fraction)
to 0.02, and make the initialized i get the next massage (before the running of the calc):
"turbulent viscosity limited to viscosity ratio of 1.00 e+5 in 27915 cells"
what it mean? do E model have a limit of volume fraction?
thanks
naor is offline   Reply With Quote
Old   December 21, 2011, 14:11
duri
duri is on a distinguished road
There is such limit on volume fraction. The mixture properties would have triggered turbulent viscosity to be very high. Try changing the inlet turbulent quantities.
duri is offline   Reply With Quote
Old   December 25, 2011, 11:37
naor
how can i do that?
thanks
Old   December 25, 2011, 12:06
duri
Sorry its mistake, I mean there is no such limitation.
Change turbulence quantities in the inlet panel and you can check values in initialization panel or contour plot after initialization.
parallel computing (MPICH2 local) error massage ggxhyst CFX 3 July 20, 2011 16:39
Strange Problem With updating the library farhagim OpenFOAM 0 August 10, 2010 12:34
Coordination Frame Problem - strange Luk_Fiz CFX 2 July 30, 2010 08:20
Strange influence of initial condition? Julien FLOW-3D 6 November 6, 2008 05:03
Strange things in SRF (urgent) Cem FLUENT 0 December 19, 2005 10:37
