combustion in fluent
Old   January 14, 2012, 13:22
Default combustion in fluent
Boudour
roukaia is on a distinguished road
Hi, I am having serious problems with what seems to be a very straight forward problem.
I have 1 inlets and an outlet. Very simple 2-D space model.
I am using the diesel/Air mixture . I have a good model with very good residuals under non-reacting conditions. I have an acceptable adapted mesh.
Problem: I apply species transport :EDDY DISSIPATION MODEL
Solution runs and the temperature increases to 1100K . inindicating combustion
Now, the residuals are good but the solution is not. The pressure inside the chamber does not increase with increasing even propellant mass flux. The only way I can increase the internal chamber pressure is by patching pressure inside the chamber .
I cant work it out and would be extremely grateful of any assistance.
roukaia is offline   Reply With Quote
coal combustion in fluent ramakant FLUENT 1 April 29, 2014 09:40
Limitation of Fluent (Combustion Modeling) Arun FLUENT 5 September 20, 2012 06:09
Combustion SImulation in Fluent santhosh1987 FLUENT 1 May 14, 2010 16:03
combustion in fluent..help ssj FLUENT 1 June 11, 2007 12:54
Fluent error in periodic PDF combustion cases?? George FLUENT 2 March 8, 2004 16:45
