January 6, 2012, 01:51 |
Skewed elements on KVLCC2 hull
Terence Chung
Rep Power: 14 |
Hi everyone. I'm meshing a ship hull on Gambit and having skewed elements on 6 faces of the hull. I have applied a curvature sizing function on the hull side and have tried various ways(eg. refining the curvature sizing function, splitted the faces with skewed elements) but they do not work so far. I have the screenshot of the mesh here. Suggestions/ reasons would be most welcome.
Thank you in advance! Terence Last edited by s7evin; January 6, 2012 at 02:59. |
January 6, 2012, 04:41 |
Maxime Perelli
Rep Power: 41 |
try to reduce the max size (in size function panel)
In memory of my friend Hervé: CFD engineer & freerider |
January 6, 2012, 12:21 |
hi
shoeb khan
Rep Power: 14 |
Just try to mesh different volumes differently with smaller mesh size.
And try to use use different schemes in areas where skewness is high. |
January 10, 2012, 02:09 |
Terence Chung
Rep Power: 14 |
Thanks mAx and shk12345! Reducing the max size for size function works!
January 16, 2012, 12:16 |
ACIS error 8032 and ACIS error 30001 encountered for KVLCC ship hull
Terence Chung
Rep Power: 14 |
I have another problem here. I'm trying to create the flow volume by subtracting the ship hull from a brick and the flow volume is multiphase, the top for the air and bottom one for water. I have persistently encountered the following errors:
1. ERROR: ACIS error 8032: inconsistent edge-face relationship 2. ERROR: ACIS error 30001: coincident face_face_ints with different body vertices. I have done the volume checks and there are no errors detected. Funnily enough, I didn't encounter this problems when I did a scaled up version of the exact same model. Sorry for the numerous questions, I am very new to Gambit. I can also send the .dbs if you think you want to have a closer look. Suggestions/ reasons are very welcome! Thanks! |
January 17, 2012, 01:16 |
Maxime Perelli
Rep Power: 41 |
substracting will only work, if you do it with 2 volumes, or 2 surfaces.
But not with a volume and a surface. In your case, your need to split your volume, with the surface. Once your split is done, you can do your other split for multiphase.
January 17, 2012, 03:14 |
Terence Chung
Rep Power: 14 |
Yeah, all were in volume form when I attempted the subtraction. I have already split the volume with surface as well. Could there be other reasons?
January 17, 2012, 03:21 |
Maxime Perelli
Rep Power: 41 |
hull volume should be fully in your outer volume (not just one half for instance), and both volume should be real
January 17, 2012, 08:04 |
hi
#9 |
shoeb khan
Rep Power: 14 |
hi
just try to make the two volume geometry in some cad model as gambit is too old now. then import in gambit and do meshing and bc there and then import in fluent. means make two real volume one your ship hull as a single volume and then make the outer two boxes and then substract them when they are 2 volumes. Or try to do that in gambit whatever suits you. Hope that will help you Regards Shk |
January 17, 2012, 12:49 |
#10 |
Terence Chung
Rep Power: 14 |
Hi max, the hull volume is fully in their outer volumes and I have aligned to ensure it is as such. Also both volumes are real. I still could not subtract to obtain the flow volume.
Hi shk12345, what cad model do you recommend? I have tried to do it on Solidworks but there was so much cleanup to be done that it was more economical to do it on gambit. Many thanks for your patience! |
January 17, 2012, 12:51 |
#11 | |
shoeb khan
Rep Power: 14 |
i hope that will make the work easier regards shk |
January 18, 2012, 07:37 |
#12 |
Maxime Perelli
Rep Power: 41 |
ok I checked your geometry (half).
You have a problem at edges 1-2-6-143-12 You may fix this issue. But I tried on the full geometry, and it is ok if you unite first both outer domains, and if you have only one hull volume. For that unite doesn t work, and you need to delete both hull volumes (lower geometry disabled). Then delete the common surface (face.81), and recreate volume from all hull surfaces. Then substract is ok. But attempting to split on the middle will fail.
January 18, 2012, 11:15 |
#13 |
Terence Chung
Rep Power: 14 |
Pardon my ignorance, but do I have to keep the flow volume split for multiphase?
January 19, 2012, 01:07 |
#14 |
Maxime Perelli
Rep Power: 41 |
Yes you can, but you should do the split, after substract is successful
January 28, 2012, 09:38 |
#15 |
Terence Chung
Rep Power: 14 |
Thank you for the advice mAx!
[ICEM] Overlapping elements | Anorky | ANSYS Meshing & Geometry | 6 | November 6, 2017 08:22 |
[ICEM] Skewed Elements at Trailing Edge. | mr_stoked | ANSYS Meshing & Geometry | 0 | September 30, 2010 07:44 |
[ICEM] Negative Volumes & 7 node HEXA elements | mr_stoked | ANSYS Meshing & Geometry | 1 | September 21, 2010 12:45 |
Problem with skew faces in simpleFoam... | HelloWorld | OpenFOAM | 7 | May 14, 2010 11:28 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 08:06 |
