Home > Forums > FLUENT
Urgent: Pump Boundary Condition
Old   January 9, 2012, 03:37
Default Urgent: Pump Boundary Condition
husker is on a distinguished road
Hi all,
I'm on a centrifugal pump analysis. My boundary conditions are 1 atm absolute pressure at the inlet and 1.66 atm static pressure at the outlet. Rotating speed of the impeller is 2100 rpm.
As a result, I obtain negative mass flow rate at the inlet which means the fluid flows reversely.
Where am I wrong? What am I supposed to do in order to monitor mass flow rate under known pressure drop values?
Regards
husker is offline   Reply With Quote
Old   January 14, 2012, 01:37
Lucky Tran
LuckyTran will become famous soon enough
A negative mass flow rate can mean that mass is entering the normal boundary. So the mass flow is going into your inlet. Are you sure your mass flow rate is reversed?
Fluent uses the outward facing normal convention for calculating fluxes.
Old   January 14, 2012, 05:47
shoeb khan
shk12345 is on a distinguished road
Sometimes when the flow is entering from the negative side of x,y or z axis fluent take it as negative mass flow inlet.
Check if that is the case in your situation
shk
shk12345 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
problem with boundary condition??? smn CFX 5 November 24, 2009 07:37
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
URGENT!!..Periodic boundary condition.. Amid Naz FLUENT 1 December 9, 2002 23:14
