Courant Number
Old   January 11, 2012, 00:16
Default Courant Number
Vaibhav Rai Khare
vaibhavraikhare is on a distinguished road
I am using VOF model for simulating..but within 1 or 2 time step courant number reach its limit and iteration stops..i reduced the time step size from 1 to 0.05 but there is no result of it..and i have to simulate it for around 1hour..
how can it be possible to increase courant number..or what is its concept..
vaibhavraikhare is offline   Reply With Quote
Old   January 11, 2012, 08:10
Default Re
Domenico
doronzo is on a distinguished road
may be the mesh resolution is involved in the Courant number?
regards
doronzo is offline   Reply With Quote
Old   January 11, 2012, 08:26
Vaibhav Rai Khare
thnx doronzo...but there is no role of mesh resolution..
Old   January 12, 2012, 07:59
JP
srjp is on a distinguished road
Did you check the flow velocity? If it is too fast through the system, it may give a problem.
Courant number = velocity * delta t / delta x
It is a measure of the ratio of simulation time step to the system time scale.
You can edit the Courant number limit in the solver settings.
Last edited by srjp; January 12, 2012 at 08:12. Reason: to correct a spelling mistake + to add some more details.
srjp is offline   Reply With Quote
Old   January 12, 2012, 08:23
Vaibhav Rai Khare
i have checked..there is no velocity in my model..i didn't give any..
how can i change courant number in solver? i have gave its value to 1 in VOF model solver setting but its not working
Old   January 13, 2012, 00:34
JP
No velocity? What are your boundary conditions?
Also, you can still try reducing your time steps.
It is always good practice to start with extremely small time steps and gradually increase it.
Old   January 13, 2012, 00:54
Vaibhav Rai Khare
Actually i am working on a water filled (30% by volume) box which is packed. there is only a pressure outlet on its upper face. The heat is given to the box by its lower surface..
Boundary Conditions Are:
Fluid (water)
outlet(pr outlet)
plate (heat is given)
i reduced time step to very small number as in VOF model the time step size should be in the form of 1e7.
But after some time (10 sec) it always increase suddenly at a particular point..and its courant number reaches very high..
Old   January 13, 2012, 22:52
Lucky
May not be directly related to the problem but, interval size plays a direct role in the calculation of the Courant number so the role of mesh resolution cannot be thrown out. Mesh resolution definitely has an impact (it is in the definition of Courant number).
Old   January 14, 2012, 05:26
shoeb khan
shk12345 is on a distinguished road
Use a time step of 1e-7 to 1e-5 and then tell me what happens.
shk
shk12345 is offline   Reply With Quote
Courant number fireman FLUENT 7 September 11, 2021 11:33
IcoFoam unstability, courant number gets large! vivien OpenFOAM 11 March 9, 2017 03:45
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number calculation - unsteady flow Kuba FLUENT 0 November 8, 2005 22:44
