Fluent Batch Mode Reg_ Urgent Help Required
1 Attachment(s)
Sir,
I am trying to run fluent in batch mode on windows platform. for that I have written batch file as fluent -g -i case.jou Howe ever when I run this batch file fluent starts its launcher, reads the journal file. Till that steps it works fine.But after that I need to manually press 'OK' to start fluent. I have attached snap shot of what I am getting on running the batch file(also in image) I have tried fluent 3d -g -i case.jou as well as fluent 3d -gu -i case.jou but in both case same prob. In fact when I write 3d or 3ddp in in front of -g and press "OK" to start running fluent it shows error that command 3ddp or 3d not recognized. So I intentionally have removed 3d. But how to counter this. I mean how to automate that I may not have to press "ok" again and again for multiple cases Please guide its extremely urgent thanks |
You should not be using the '-i' flag for running a standard journal file.
Also your syntax is incorrect, you must pipe the journal file into fluent. Try: fluent 3d -g < yourjournalfile.jou This is correct for Unix systems, I am unsure if there is a different syntax for Windows. Stu PS, Please refrain from posting your question in multiple threads next time. |
Sir,
I will keep note of not posting it in multiple forums.I apologize to all members reg same. Could you please tell me what you mean when you standard journal file.Actually I saw the syntax in their documentation that's why I preferred to go that way. But still I will try what you have mentioned.. Thanks |
From what I remember, the "-i" flag is used when you are passing an XML document to Fluent with session parameters. If you are passing just the journal file, you do not need the "-i" flag.
fluent 3ddp -g -i case.jou is a valid batch command for Windows.
You can test this by typing "fluent 3ddp" in Start > Run and see if Fluent starts. there may be some problem with the fluent settings in the environmental variables for windows. |
