2D airfoil at 15deg
1 Attachment(s)
I have tried the tutorial of a naca0012 airfoil which is done with a C-grid, and at a 6deg angle.
Here is the link to the toutorial: https://confluence.cornell.edu/displ...oil+-+Geometry I have tried it an it works fine, but then I just changed the x and y velocitys so the airfoil is at a 15deg angle, with all the other settings the same, I run the calculation and it does not give out a result. See attached picture. Does anyone have any idea why is this or how to correct it? Maybe something not right in the setup? |
Just low value of under relazation factor and try to use different schemes.
Thank you! |
there are several schemes like
24.2.1 First-Order Upwind Scheme 24.2.2 Power-Law Scheme 24.2.3 Second-Order Upwind Scheme 24.2.4 QUICK Scheme see this page for more detail http://jullio.pe.kr/fluent6.1/help/html/ug/node814.htm just google more for more results shk |
I had it set at Second-Order Upwind.
First-Order Upwind Scheme gave me unreal results. The lif coefficient was 1.3 for the 15 deg angle, but at 10deg it was 2.1(with second order upwind) And there are only these two schemes available, where can i find the power-law scheme, or quick scheme? |
Try to use the Pressure velocity coupling as : coupled, solver and first order scheme it best faster convergence
then once the solution is conveged switch to second order and get the results. |
There could also be stall at such high angle of attacks which produce such a behaviour... What do you mean with "it does not give out a result"? No convergence?
I have a similar problem and i also dont know what to do now... http://www.cfd-online.com/Forums/flu...-possible.html |
Sometimes a oscillation convergence is also accepted like in your case.But it will be better if you can try to get a stable solution shk |
