Problem with organic fluid property
i'm simulating a radial turbine that works with organic fluid. This Fluid there isn't in fluent database. I create it and i select this properties: cp, density, viscosity, thermal condicivity, Molecular Weight, standard hentalpy/entropy status calculated as avarage value between inlet and outlet turbine boundary conditions, Pcritical, Tcritical, refence temperature as 298,15 K. The results are very bad and abnormall and i don't understand it. Help me, please. Thank you. |
