Courant Number
I am using VOF model for simulating..but within 1 or 2 time step courant number reach its limit and iteration stops..i reduced the time step size from 1 to 0.05 but there is no result of it..and i have to simulate it for around 1hour..
how can it be possible to increase courant number..or what is its concept.. |
Re
may be the mesh resolution is involved in the Courant number?
regards |
thnx doronzo...but there is no role of mesh resolution..
Did you check the flow velocity? If it is too fast through the system, it may give a problem.
Courant number = velocity * delta t / delta x It is a measure of the ratio of simulation time step to the system time scale. You can edit the Courant number limit in the solver settings. |
i have checked..there is no velocity in my model..i didn't give any..
how can i change courant number in solver? i have gave its value to 1 in VOF model solver setting but its not working |
No velocity? What are your boundary conditions?
Also, you can still try reducing your time steps. It is always good practice to start with extremely small time steps and gradually increase it. |
Actually i am working on a water filled (30% by volume) box which is packed. there is only a pressure outlet on its upper face. The heat is given to the box by its lower surface..
Boundary Conditions Are: Fluid (water) outlet(pr outlet) plate (heat is given) i reduced time step to very small number as in VOF model the time step size should be in the form of 1e7. But after some time (10 sec) it always increase suddenly at a particular point..and its courant number reaches very high.. |
Use a time step of 1e-7 to 1e-5 and then tell me what happens.
shk |
