Home > Forums > FLUENT
Turorials on pipe flow
Like Tree1Likes
  • 1 Post By ghost82
Old   January 12, 2012, 12:24
Default Turorials on pipe flow
Gamb1t is on a distinguished road
Hi everybody,
I was just wondering if any of you guys know of a tutorial that will guide one in gambit/fluent in making a simple pipe so that I can show the fluid going to fully developed and see the pressure drop as flow goes along the pipe.
I thought it was simple to do geometry as in just have a top line and bottom line, however I have been told that I had to do a slice of the circle. I am confused. Does anyone know what he means?
Gamb1t is offline   Reply With Quote
Old   January 13, 2012, 03:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
2d?
3d?
is your pipe straight?
http://202.118.250.111:8080/fluent/G...guide/tg03.htm
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 13, 2012, 10:45
Default pipe flow
Thank you Max for a reply.
I have done that tutorial you posted. The pipe I am doing is straight. My supervisor told me that since the pipe is asymmetric I have to do a slice of the pipe. He said if its difficult to do I can do planar and lose considerable marks so am assuming its in 3D. Below is the diagram of what he said I had to do.
He said since its asymmetric I just have to consider the slice as there is no need to consider the whole pipe?
Old   January 13, 2012, 12:36
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
well, you can draw and simulate:
1- a 2d axisymmetric tube, by drawing 4 points (2 for the axis and 2 for the upper part of the tube), create edges and the surface, mesh it and apply boundary conditions for inlet, outlet, wall and axis; this means drawing half of the tube you have attached and simulate a 2d axisymmetric problem.
2- you can draw and simulate the 3d tube, by drawing a cilinder and assigning boundary conditions, inlet, outlet and wall.
3- you can draw and simulate a slice, for example 1/4 of the tube (3d), by drawing 1/4 of cilinder and assigning boundary conditions, inlet, outlet, wall and periodic (for the 2 rectangular faces); when you mesh the reactangular faces you have to link them. Then in fluent you will set periodic conditions.
4- you can draw and simulate 3d half pipe, by drawing half cilinder and assigning boundary conditions, inlet, outlet, wall and simmetry (to the rectangular face).
The simplest one is the 2d axisymmetric problem.
Hope that helps
Daniele
mrenergy likes this.
ghost82 is online now   Reply With Quote
Old   January 13, 2012, 16:10
I think point 3 sounds like what I meant to be doing. What is the reason for simulating just a slice as opposed to half the pipe or a full pipe, is there advantages?
Is there a guide on how to simulate a slice? If not do you mean draw a cylinder first. Then take away some volume, say 3/4 of it. Then add two rectangles to close the cylinder. Then do boundary conditions.
Thank you
Old   January 13, 2012, 23:59
Lucky Tran
LuckyTran will become famous soon enough
Thank you
There is the most obvious advantage of reducing the overall computation cost by simulating the smallest representative domain of the whole problem. From symmetry and periodicity arguments, the solution to the quarter pipe simulation should be exactly the same as the full pipe problem. The same argument goes for the half-pipe. Half-pipe is smaller than a full-pipe. A quarter-pipe is even smaller than a half-pipe. So solve the quarter-pipe.
Your outline is correct. Create a 3D representation of the 1/4 cylinder (however you are most comfortable with) by closing the two faces (which will be rectangles). Then Mesh it. Then import into fluent and start setting up the problem.
Old   January 14, 2012, 04:41
ghost82's Avatar
Daniele
Thank you
You should obtain the same results with all simulations.
The less expensive in termes of computational cost is the 2d axisymmetric.
If you want to draw 1/4 pipe, in gambit you can draw the full cilinder, then draw a square base prism with one vertex of the base with the same coordinate of the center of one base of the cilinder, with side of the base equal or greater than the radius of the circle, and with prism height equal or greater than the height of the cilinder.
After that you can intersect the two volumes and you will obtain the 1/4 cilinder, you don't have to create any further face..
In the mesh tab, link the two rectangular faces, premesh other edges/faces and mesh the volume.
Set boundary conditions, export the 3d mesh, start fluent and set your problem.
Daniele
Old   January 14, 2012, 16:59
Thank you for replies. I think I now know how its meant to be done. I will try on Monday to get this pipe out of the way. Danielle, that attached thumbnail really helped my understanding.
Old   January 15, 2012, 09:57
I have another point: Since I am trying to find when the flow becomes fully developed and when a pressure drop occurs, does it mean I have to make a really long pipe or is there another way to do it. Thanks.
Old   January 15, 2012, 10:40
ghost82's Avatar
Daniele
You can estimate the length for fully developed flow in pipe:
for laminar flows:
El=0.06*Re
le=El*d
for turbulent flows:
El=4.4*Re^(1/6)
le=El*d
Where:
El=Entrance Length Number (dimensionless)
Re=Reynolds number
le=length to fully developed velocity profile
d=pipe diameter
Make sure to draw a pipe longer than the length to fully developed velocity profile.
PS: pressure drop occur all along the pipe, even after the flow is fully developed..
Daniele
Old   January 15, 2012, 12:18
Lucky Tran
I am a little confused.
If you are studying the developing length, then of course you would need a really long pipe. Or is that not the problem?
You can simulate only the fully developed portion and not use any entrance length if all you care about is flow after it has become fully developed, is that your problem?
Old   January 15, 2012, 13:55
I am studying incompressible pipe flow. I don't have to particularly study the developing length but thought it would be something good to do since its the only thing I can think of. After the straight pipe I would need to do a pipe with orifice plate inside it. I think for that I would need to simulate flow after it becomes fully developed.
Daniele, thanks for those equations. Really appreciate it.
Old   February 11, 2013, 18:37
Jing Shi
Jing is on a distinguished road
Hope that helps
Daniele
Hi, see your good answer to that question.
I have a question, if I use a 2d pipe tube by drawing 4 points (2 for the upper parter and two for the bottom), create edges and the surface, mesh it and apply bounday conditions for inlet, outlet, wall and simulate a 2d planar problem, it is not right, is it? The results are not in agreement with 3d tube.
Jing is offline   Reply With Quote
Old   February 12, 2013, 05:52
ghost82's Avatar
Daniele
Hi!
it is not correct if you simulate it as a 2d planar problem; in 2d planar you are simulating a squared-rectangular base conduct with a depth equal to the value you set in the reference values panel.
To compare results with 3d simulation you have to simulate it as 2d axisymmetric.
Daniele
Old   February 12, 2013, 05:55
Jing Shi
Thank you very much!
Regards, Jing
Old   February 17, 2013, 08:57
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
3- you can draw and simulate a slice, for example 1/4 of the tube (3d), by drawing 1/4 of cylinder and assigning boundary conditions, inlet, outlet, wall and periodic (for the 2 rectangular faces); when you mesh the rectangular faces you have to link them. Then in fluent you will set periodic conditions.
Shouldn't we apply symmetry on both sides?
Far is offline   Reply With Quote
Thread Tools
Trackbacks are On
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
HTC in Pipe flow subsemitonium CFX 6 May 6, 2013 22:00
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
