Home > Forums > FLUENT
Interpolation of the results....HOW???
Old   January 16, 2012, 14:54
Default Interpolation of the results....HOW???
mohammad
mohammad is on a distinguished road
Hello everybody,
I have a question about interpolation of the results for same models [with different node arrangements and same Geometries.]
As i know this is possible in CFX that we initially solve the model with fewer nodes for a while, then use the results as the initial values and run the same geometry with just higher number of nodes.
Is this method possible in FLUENT? and how should i import the initial value file.
regards,
mohammad is offline   Reply With Quote
Old   January 16, 2012, 16:14
Amir's Avatar
Amir
Amir is on a distinguished road
file->interpolate (refer to manual)
Bests,
Amir
Amir is offline   Reply With Quote
Old   January 17, 2012, 10:19
shoeb khan
shk12345 is on a distinguished road
hi amir
tell me something more about the interpolate .
shk
shk12345 is offline   Reply With Quote
Old   January 23, 2012, 07:47
Smile
mohammad
Hi everybody, hi Amir
I did it as the help manual...but the results are awkward...about 500 times bigger than what i expected.
1) I made a model with small number of nodes----> I solved it---> results look to be in-range.---> i saved an "Interpolate" file
2) I generated the same model with higher number of nodes---->I imported the "interpolate" file from step 1---> i ran the model
https://www.sharcnet.ca/Software/Flu...ug/node137.htm
as i told , the results are really bad....
what could be the cause?
Regards,
Old   January 23, 2012, 09:12
Amir's Avatar
Amir
Did you save all of the fields in interpolate file? velocity, pressure, ....
Did you save the interpolate file of the converged solution?
when you import the interpolate file in a finer grid, check all the fields and BCs before iteration. At last, maybe your solution hasn't converged yet.
Bests,
Amir
Old   January 23, 2012, 14:28
mohammad
Hi dear Amir,
All are ok...but i think the last one is the cause.
Anyway...thank you for your help man.
Regards
Thread Tools
Trackbacks are On
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 16:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 15:32
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 08:25
interpolation or mapping a result into another model amazdeh CFX 5 April 1, 2009 09:45
Wrong result with bilinear interpolation zonexo Main CFD Forum 1 June 12, 2007 15:55
