Velocity gradient tensor
Old   January 23, 2011, 09:33
Default Velocity gradient tensor
kumaran
kumaran is on a distinguished road
Hello there,
could anyone suggest how to extract second invariant of the velocity gradient tensor from fluent?
I am using Fluent v12
Thanks
kumaran is offline   Reply With Quote
Old   January 24, 2011, 07:06
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
Yes i know how you should do it!
I did it for calculation of frictional solid viscocity in Euler -Eule granular material simulation.
If you want the IId in a UDF you should obtain the derivatives of velocity in each direction
(C_DUDX(cell, thread), C_DVDX(cell, thread), C_DWDX(cell, thread) etc. (check the command in the UDF manual).
and then just use the formula. ND_ND parameter will help you in order to obtain a code that works for 2-D and 3-D.
If you want the IId just for plotting define a custom field function (Fluent -> Define -> define a custom field function )
Be careful in this: Are you sure that you want to calculate the second invariant of gradU??? Or you want the second invariant of the deviatoric part of rate-of-strain tensor?
Nikolopoulos is offline   Reply With Quote
Old   January 25, 2011, 07:56
kumaran
hello Nikolopoulos,
thank you for your response.
I am looking for the IId of gad U to look at the coherent vortices in 3D.
i am not that familiar with the UDF.. do you mind sharing the UDF file that has the skeleton? so that i can try to modify it ?
Thanks
Old   January 26, 2011, 01:31
Do you want it only for post process?
Old   January 26, 2011, 02:15
kumaran
hi,
yes. i want only for post process to see the streamwise vortices in teh midsection of the domain
Thanks
Old   January 25, 2012, 03:00
Default udf for velocity tensor
studen
studen is on a distinguished road
hi kumaran and nick, i also need to see the velocity tensor for my simulation can u pls share the udf file.
regards and thnks in advance
studen is offline   Reply With Quote
Transformation of a cartesian velocity gradient volTensorField to cylindrical coord. alexey7783 OpenFOAM 5 April 26, 2012 18:29
About deformation gradient tensor ZHANG Main CFD Forum 0 June 18, 2007 12:51
UDF sample for velocity gradient J.Y.Shin FLUENT 2 January 19, 2007 18:04
velocity gradient Merinadica FLUENT 0 December 16, 2006 04:53
Second invariant of velocity Gradient Funda Siemens 2 September 28, 2004 06:18
