-   FLUENT (
-   -   CFX results as initial value for FLUENT 6.3 (
mohammad January 21, 2012 14:19
Hi everybody....
I have a result file of CFX 11. I am trying to import it as the initial values for FLUENT form the following path.
File > Import > CFX > Results File
The problem is that the results ( Monitors of fluent) don't look like normal( in range), while the initial values are in range.
Also if I RUN the fluent file without that initial file from beginning, again the results look normal.
Does this matter seem OK? If not, what could be the cause of the problem?
mohammad January 23, 2012 07:39
Hi everybody.
I found the answer.
According to FLUENT 6.3 help manual, it is not possible.
