-   -   Moving Mesh Fluent (http://www.cfd-online.com/Forums/fluent/96407-moving-mesh-fluent.html)
ChrisR January 22, 2012 06:30
Moving Mesh Fluent
Hey there!
I wanna simulate a cylinder motion in Ansys Fluent but i always get the "negative element"- error.
I got 1 rigit body call "bottom", and the sidewalls call "wall" as deforming body.
The moition works and looks like the picture below :
http://imageshack.us/photo/my-images...enannt1wy.jpg/
I'm pretty new to fluent and don't know whats my failture is
I think it looks like my wall move but my domain is stationary and thats the reason why my fluid domain is outside the walls? Correct me if i'm wrong.
I think i got a major issue in my understanding of the moving mesh :-)
Is there any good tutorial for moving mesh?
Updating solution at time level N... done.
Updating mesh at time level N...
Info: Maximum Cell Skewness outside reasonable limits, using 0.7 instead.
global conserved variables:
domain 1: ( 6.44971e-04 0.00000e+00 2.04581e-06 2.24282e-03 4.28291e-06 0.00000e+00 7.41762e-04 0.00000e+00 0.00000e+00 )
domain 1: ( 6.44971e-04 0.00000e+00 2.04581e-06 2.24282e-03 4.28291e-06 0.00000e+00 7.41762e-04 0.00000e+00 0.00000e+00 )done.
Warning: non-positive volumes exist.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
Cola1988 January 22, 2012 17:03
I think i now the problem but i have no solution
Hey Dude,
I think I know your mistake.
It looks like your mesh doesn't deform. Your boundary ( piston bottom) simply moves up- and downwards. Is this assumption correct?
I think you have to couple the cylinder wall and the piston bottom to make the same movement. I think the mistake is somethng with your domain nd the moving mesh. Have you looked on re-meshin elemnts and so on?
Regards Phil
ChrisR January 22, 2012 17:05
Correct.
How can i fix it? Does anybody know?
Sugajen January 24, 2012 02:33
Hi there
I'm new to Fluent. Trying to move a piston by applying pressure. How should i do it?
