-   -   Flamelet Parameters (http://www.cfd-online.com/Forums/fluent/96435-flamelet-parameters.html)
andre9 January 23, 2012 06:34
Flamelet Parameters
I'm starting to make reactive simulations using Steady Flamelet models. My objective is to simulate a hydrogen flame in air in a tipical bluff-body configuration. I'm using the Burke 2011 kinetic model (8 species + inerts and 19 reactions).
There is any golden rule to determine the following parameters to calculate the flamelet and generate the pdf table?
  • Number of Grid Points in Flamelet
  • Maximum Number of Flamelets
  • Number of Mean Mixture Fraction Points
  • Number of Mixture Fraction Variance Points
faudiS8 May 20, 2012 06:28
hi every body
is there anyone here to answer the question?
It's mine too!
Also I want to know if there's any optimum under-relaxations?
My model convergence has many fluctuations.
kingpots November 19, 2012 17:23
Hi all ,
As far as i know there isn't any golden rule , however you can validate your results by looking to the Flamelet shape, species , scalar dissipation and mixture fractions .
I am always using the automated refinement with 8 to 40 points /20 flamelets and it gives good results . Check also the time vs . residuels while creating flamletes ,if it is smooth then you are good to go , if on the other hand it takes long time , try to redude the fourrier no. to 1 .
