Home > Forums > FLUENT
Wrong temperature/pressure under constant gravity
Old   January 29, 2012, 21:22
Default Wrong temperature/pressure under constant gravity
jpo
jpo is on a distinguished road
I am trying to demonstrate the influence of gravity on a vertical air column. I did this simulation:
Constant gravity against z, gravity = -981 m/s^2 (very high, but good to visualize the effect)
Fluid: 15m vertical air column (adiabatic walls), no flow
Initialize at 300K and 1 atm
volume is closed, no inlets/outlets
Residuals drop down but not smoothly
Temperature and pressure rise in the volume
perhaps someone has done this before and can give advice?
jpo is offline   Reply With Quote
Old   January 29, 2012, 21:50
Real Name :)
ComputerGuy is on a distinguished road
JPO,
Pressure won't be uniform in the volume, nor will temperature at first. The gravity, which is 100 times higher than normal, should cause pressure at the base to be:
\rho \cdot g \cdot h
or
density of the air (assume you're using ideal gas) * 981 * 15
Temperature should also change as the gas at the base is compressed, but given that it's adiabatic, should begin to become more uniform as thermal diffusion/convection make everything even.
Note that closed boundary problems are often quite difficult to converge, especially when you have variable temperature/pressure properties and (I'm guessing) initialization with 0 velocity.
A better way to demonstrate this is to make the top of your domain have a pressure boundary of 0 Pa gauge, and the bottom to have a mass flow of something like 0.00001 kg/s. The rate of flow is likely to be smaller than the rate you'll get due to natural convection, and you'll see the influence of gravity very well on your system (pressure at the bottom should be equal to what I've written above)
Enjoy!
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   January 29, 2012, 22:24
jpo
Thank you ComputerGuy, I will try this... If a sealed domain (almost) converged, this one should be easier to converge
Trying it now...
Old   January 30, 2012, 14:18
jpo
Yes, I see the pressure difference (unchecked whether it conforms to the hydrostatic equation, but it should) and a temperature and density differences as well
This should be seen at any outlet pressure though... only the density/pressure/temp at the bottom should readjust to accomodate the change, if I understand this correctly
Thread Tools
Trackbacks are On
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Considering Gravity effect(or Hydradynamic) in CFX klarke CFX 7 October 2, 2006 03:53
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Free Surface Gravity Driven Flow Rupp Carriveau FLUENT 4 June 14, 2001 16:54
