Home > Forums > FLUENT
regarding periodic boundary condition
Old   March 31, 2012, 02:53
mohamed khedr emam
m5edr is on a distinguished road
Originally Posted by Edu-R View Post
Hi m5edr,
Did you solve the problem? I have the same problem and I don't know what causes or what can I do
Thanks in advance!
Regards
Pls explain which part you need
thanks
m5edr is offline   Reply With Quote
Old   March 31, 2012, 07:31
Edu
Edu-R is on a distinguished road
Hi!
I have done a mesh with the match control option, and it works well, but when I try to make the zones periodic in Fluent it gives me the same message of your first post.
Regards
EDIT: Sorry, the message is the one that appears in the first post of discussion, not in your post. Thanks in advance!
Edu-R is offline   Reply With Quote
Old   April 3, 2012, 02:17
mohamed khedr emam
Hi!
Regards
this may help you
periodic boundaries
regrads
Old   April 3, 2012, 05:29
Edu
Originally Posted by m5edr View Post
this may help you
periodic boundaries
regrads
I have remeshed the geometry and I don't have the problem right now, but I will try this solution when the message appears again.
Thank you very much!
Regards
Old   June 27, 2012, 08:05
Marx
Marx is on a distinguished road
Normally there could two reason for this error. First check the origin of rotation.
So how do we check, open the design in design modeler then use point entity to check the centre of rotation coordinate. u can even draw on the surface of your model and find the centre of rotation. (anyway works). if its rotating along z axis then get the x and y coordinate and place it in fleunt>cell zone condition> rotation axis origin.
if it does work then maybe its due to different number of cell on the face of the two surface. It a non conformal periodic.(https://www.sharcnet.ca/Software/Flu...ug/node186.htm) you have change the type of B.c from wall to interface then use Mesh Interface where you select the surfaces, check the periodic B.C set the angel offset and create periodic.
Marx is offline   Reply With Quote
Old   October 14, 2012, 10:11
mohamed khedr emam
I couldn't do this step .... could you explain this step in details
thanks in advance
Thread Tools
Trackbacks are On
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 2 August 14, 2014 09:07
periodic boundary condition (translational) fluent 6.3 haihek FLUENT 3 January 22, 2014 05:10
periodic boundary condition in LES martor FLUENT 2 April 10, 2012 19:17
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 08:39
