regarding periodic boundary condition
Old   January 30, 2012, 04:40
Default regarding periodic boundary condition
cfd
raki_mech81@yahoo.co.in is on a distinguished road
Hi
I want to give Periodic boundary condition on blades but it is giving error as below...
/grid> modify-zones
/grid/modify-zones> make-periodic
Periodic zone [()] periodic_1
Shadow zone [()] periodic_2
Rotational periodic? (if no, translational) [yes]
Create periodic zones? [yes]
zone 12: matched 0 out of 676 faces.
zone 13: matched 0 out of 676 faces.
Error: Failed to make zones periodic.
Error Object: #f
/grid/modify-zones>
What is the reason and how it can be corrected...
Thanks in advance
raki_mech81@yahoo.co.in is offline   Reply With Quote
Old   February 25, 2012, 06:24
Default Re
mohamed khedr emam
m5edr is on a distinguished road
I'm face the same problem
any help pls,
m5edr is offline   Reply With Quote
Old   February 25, 2012, 09:10
shoeb khan
shk12345 is on a distinguished road
Hello
For periodic boundary conditions give the boundary conditions in gambit itself and then when you will export to fluent it be a periodic boundary condition
second define it with any name and boundary types in gambit and then in fluent go to the boundary condition and change the boundary type to periodic
thanks
hope that will help you
shk12345 is offline   Reply With Quote
Old   February 25, 2012, 11:53
Default Re
mohamed khedr emam
Many thanks for replay BUT the problem is:
I'm using Ansys Workbench, so I'm used Ansys Mesher Not Gambit in my meshing my geometry
Do you know who to solve this with Ansys?
thanks again
Old   February 25, 2012, 11:57
shoeb khan
yup i know
give any boundary condition name there is ansys mesher
and then go to fluent in bounday condition change it to symmetry
that's it
Old   February 25, 2012, 12:06
mohamed khedr emam
You mean, I change the b.c to symmetry
THEN make it periodic by write the following command in fluent window:mesh -> modify-zones -> make-periodic
Old   February 25, 2012, 12:09
shoeb khan
no
go to boundary conditions
there change the boundary condition of those ares to symmetry.
Old   February 25, 2012, 12:24
mohamed khedr emam
Sorry , i can't understand
I have 1/3 cylinder, the sided faces should be periodic.
Is Symmetry equivalent to Periodic type!!!
Old   February 25, 2012, 12:31
shoeb khan
send me the files i will try to tell you how to do
Old   February 25, 2012, 12:36
mohamed khedr emam
Thanks
Mail pls
(the files are 11 MB)
Old   February 25, 2012, 12:37
shoeb khan
send me geo with meshing in zip form in ansys 13 or 14 format
Old   February 25, 2012, 12:48
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
No symmetry is not equivalent to periodic. In figure you said the wall should be interior, rather it should be interface: one for internal fluid and one for external fluid.
Far is offline   Reply With Quote
Old   February 25, 2012, 13:07
Default Re
  #13
mohamed khedr emam
Dear/Far
No it was an an old problem, i solved it
sorry
Now, i have to define the "periodic type zone" to the two faces as appear in this pic
I'm made Match Face control in Ansys Mesher , Then i opened the fluent
and write the following (mesh -> modify-zones -> make-periodic)
After that fluent appear the first massage in this discussion !!
Old   February 25, 2012, 14:17
Far
Sijal
you can try this solution and accuracy is as good as pure periodic planes. you can write them as interface and then go to interface panel and then define them as interface with periodic condition.
I shall look into this issue, as I used to get this message in starting of my career.
Old   February 25, 2012, 14:27
mohamed khedr emam
Thanks ,Far
But interface solution cause dispersion to me ( i tried it before)
if you find solution, tell me pls
thanks again
Old   February 25, 2012, 14:28
Far
Sijal
I used it many times and it is as good as periodic boundary. Send files through file sharing
Old   February 25, 2012, 14:44
Default Re
  #17
mohamed khedr emam
Thanks but
Case File is 9 Mb
can't be attached
Old   February 25, 2012, 14:47
Far
Sijal
use 4shared http://www.4shared.com/
Old   February 25, 2012, 15:00
mohamed khedr emam
http://www.4shared.com/file/Xf_fq-6s/FFF.html
Many thanks Far
Old   March 30, 2012, 15:33
Edu
Edu-R is on a distinguished road
Hi m5edr,
Did you solve the problem? I have the same problem and I don't know what causes or what can I do
Thanks in advance!
Regards
Edu-R is offline   Reply With Quote
periodic boundary condition in LES martor FLUENT 3 April 30, 2022 00:20
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
periodic boundary condition (translational) fluent 6.3 haihek FLUENT 3 January 22, 2014 04:10
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 08:39
