[Sponsors] | |||||
Rep Power: 4 ![]() |
Dear all,
I have two simple questions regarding rotational periodic boundary conditions. The model is a 6-holes nozzle inside a cylindrical pipe - I am modelling a 60° sector with 3D tetrahedral elements. 1. Shall the axis of rotation be the x axis in Fluent? 2. Shall the two opposite faces defining the 60° sector be coupled in one part, so to apply only one PERIODIC boundary condition? I am using ICEM for geometry + mesh + boundary conditions. I made some trials, but Fluent gives undefined error during calculation of first iteration. Thank you very much! Sergio |
Rep Power: 3 ![]() |
1. Shall the axis of rotation be the x axis in Fluent? Yes, you can 2. Shall the two opposite faces defining the 60° sector be coupled in one part, so to apply only one PERIODIC boundary condition? I am using ICEM for geometry + mesh + boundary conditions. If the two periodic boundaries are in separate parts, the periodicity can be defined in ICEM by first defining the axis and angle in 'Mesh -> Global mesh setup -> Define periodicity' Then 'Blocking -> Edit block -> Periodic vertices' selected the periodic pairs. After creating all the periodic vertices, in the display control tree, activate Faces and verify by right clicking on Faces -> Periodic Faces. All the periodic faces should appear 'red'. If this is done, Fluent automatically shows only one periodic boundary on which rotational periodicity have to be specified. |
Hello!
1. I understand it is not mandatory to use the x axis as axis of rotation (for instance, in 2D axisymmetric problems, the axis of revolution has to be the x axis) 2. I've checked my models with the Mesh -> Periodicity from the display control tree. If the two opposite faces defining the 60° sector are coupled in one part, there is no periodicity relation though I created the mesh with Global Mesh setup parameters. If the two opposite faces belong to two different parts, I see the periodicity relation (the opposite nodes are linked by straight green lines). I apply then the periodic BC to the parts in ICEM. Now, when Fluent reads the mesh file of the correct ICEM model, one periodic part is OK, for the other the following message appears: "Skipping zone periodic_sh (not referenced by grid)" and the part gets deleted. Is this normal? I guess Fluent couples the two parts, one as periodic and the other as shadow... The fact is that the simulation does not run, I don't know if due to wrong periodic BC or to the use of multispecies+density-based solver+periodic BC (I have read somewhere that periodic BCs cannot be used by density-based solver when chemical species are activated). Might you help? Thank you very much! Sergio |
Have you created "periodic pairs" of the vertices on periodic faces in ICEM? Regards |
Helllo,
I don't need to create periodic pairs of vertices as the mesh is made of tetras. The ICEM model with two parts (each with one periodic face) is working fine. The simulation does not run with the density-based solver or with the coupled pressure-based solver, while it runs well with the segregated pressure-based solver. Energy, species and turbulence are activated, fluids have properties changing with temperature. Residuals go as low as 10^-5, more iterations do not decrease their values. How to get 10^-6? Should I increase under-relaxation factors? Thank you very much! Sergio |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Periodic boundary conditions in 3D Eulerian granular flow simulations | dsm | FLUENT | 4 | March 2, 2012 19:04 |
| Problem with using periodic boundary conditions | Sun | FLUENT | 0 | January 14, 2011 09:47 |
| Urgent: periodic boundary conditions | ck1973 | FLUENT | 3 | July 5, 2006 11:32 |
| How to apply a periodic boundary conditions | ck1973 | FLUENT | 2 | July 4, 2006 01:27 |
| periodic boundary conditions fro pressure | Salem | Main CFD Forum | 20 | September 29, 2005 03:58 |
