Home > Forums > FLUENT
Help needed
Old   February 2, 2012, 00:30
Default Help needed
Abhijeet Shrawage
ashrawage is on a distinguished road
Guys,
I have a similar problem regarding my work
I will explain it in a few lines.
I have to simulate a very concentrated Brine solution entering in a tank where it is superheated to 410 degrees C and here the salt is separated since the water turns into water vapor. The vapor then just exits from the outlet at the top and the salt is deposited at the bottom.
My questions are
Can i use the idea that you suggested to Mohsin about fooling FLuent and creating a NaCl material using the properties of salt found online?
2) Can i use DPM for this or which other model will be best for this type of a problem
3) I will need to make sure the salt is dissolved in the water at the inlet. So can i do this using Species transport?
4) What about the actual evaporation process taking place? I need help with the UDF for the evaporation or is there any other way around it?
Please guys I am desperate. I really need help or else i am looking at another year wasted.
THANK YOU
Abhijeet
as195810@ohio.edu
ashrawage is offline   Reply With Quote
Thread Tools
Trackbacks are On
a CFD software is needed... maxgzc Main CFD Forum 3 September 27, 2011 01:51
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
Extremely high Temperature needed to simulate pressurization with rhoCentralFoam shangzung OpenFOAM Running, Solving & CFD 0 August 6, 2010 06:35
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
CFD Software Engineer needed in Fort Worth, Texas Ross Main CFD Forum 0 November 19, 2001 14:48
