January 31, 2012, 11:14 |
Student in need of help! 2-D airfoil problem
Orion Modebe
Rep Power: 14 |
Hi
I'm currently trying to run a 2D airfoil in fluent to find if there is any significant separation when a small flat plate is attached to the trailing edge. It is a follow up from a wind tunnel experiment, so it is supposed to replicate the airfoil in a wind tunnel. The problem is that I'm not sure which is the best turbulence model to use, or if I should be using in order to replicate the wind tunnel. I believe it would be best to use either Spalart allmans model or the K-w model but I'm not sure which would be best. Any advice on which one to use would be much appreciated. Thanks |
February 1, 2012, 11:26 |
Orion Modebe
Rep Power: 14 |
yes i did, but that uses the spalart allmans model. I was hoping for a bit of guidnce in terms of which would be better to be analysing separation and the boundary layer?
February 2, 2012, 16:16 |
I have a model
CFD
Rep Power: 16 |
I have a model for airfoial from zero to finish if u need it send a private message
Display Modes | |
Convergence Problem icoFoam steady flow over an airfoil | Lucas | OpenFOAM Running, Solving & CFD | 6 | July 12, 2018 15:06 |
2D SST Simulation Airfoil - Convergence Problem | Kraemer | CFX | 10 | April 16, 2011 07:22 |
Fluid Structure Interaction problem for airfoil | vinair39 | OpenFOAM | 0 | February 8, 2011 07:57 |
Residual problem of 2D airfoil simulation | caohan | FLUENT | 9 | April 13, 2010 16:03 |
airfoil, mesh spacing problem, CFX-ICEM | Santiago Orrego. | CFX | 3 | January 14, 2007 18:19 |
